Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
Throwout Bearing woes... #231511
01/20/12 04:29 PM
01/20/12 04:29 PM
denver
3
3rdowner Offline OP
3rdowner  Offline OP
denver
I am terribly confused as to the correct throw-out bearing set-up for my 1926 Superior Roadster. I have not been successful at posting pictures in the past, but I will attempt again. In words, here is the problem: I have attempted to purchase a replacement carbon throw-out bearing, but all received have the wrong inside diameter. Upon talking with many people, I have learned that there are several different styles used. My car came with a bearing that slips on the transmission shaft, thus keeping it concentric and aligned with the throw-out sleeve. It has a 1.172 I.D. The replacement bearing has a 1.500 I.D., and would float on the shaft. Here is the kicker: my throw-out collar does NOT have a flange or split clam, it is simply a bearing face on the arm. I have attempted to attach pictures of this situation. I was told that the collar should have a split clamp, however, if that is the case, there is no way it will align with the pocket on the sleeve, the sleeve would have to be without a flange, as the bearing only has 10 thousands clearance . Good news, all bearing have the same O.D., so I’ve got that going for me. Question, which collar-sleeve combination is correct? See pictures
Uploaded with ImageShack.us
The Filling Station 1912-28
Re: Throwout Bearing woes... [Re: 3rdowner] #231518
01/20/12 05:58 PM
01/20/12 05:58 PM
Vancouver, WA
AntiqueMechanic Offline
ChatMaster - 9,000
Vancouver, WA
Use the bottom arm as pictured with the clamp and the new bearing and you will be ready to go. The size of the center hole is not that important. Your new bearing should have a curved face and you should have received instructions with it on how it is to be mounted.
devil Agrin
Member Chat Group - Non-Geographical Region
Re: Throwout Bearing woes... [Re: AntiqueMechanic] #231520
01/20/12 06:24 PM
01/20/12 06:24 PM
denver
3
3rdowner Offline OP
3rdowner  Offline OP
denver
Ray,
The new bearing has sharp edges, as see in the second group of pics, on the right. But what I’m hearing is that the clamp is correct. I didn’t receive any instructions with the new bearing, but I can place a radius on the lead-in edge. Do you have instructions you can post? Should the sleeve have a flange? And last, where the heck did the unit come from that is on the car? It is properly marked as GM
PS Thanks!
Re: Throwout Bearing woes... [Re: 3rdowner] #231523
01/20/12 06:37 PM
01/20/12 06:37 PM
The Great State of TEXAS
Chipper Offline
Chipper  Offline
The parts shown are essentially the opposite of what I have seen on other Chevys. The bottom arm photo is what I am familiar with. It mates with a smooth faced four slotted part (sleeve) that connects to the pressure plate arms.
In your case it looks like the carbon is pressed into the slotted part (sleeve) and rides on the smooth throwout plate on the clutch arm. It should work by fitting the carbon into the sleeve. The id difference should not be a problem as both the arm and sleeve have limited up & down movement.
Either type would work but each requires the correct parts to function. Looks like you need to order part number AF-63 or maybe part number CV-102 (modern replacement) from the Filling Station or another part supplier.
Re: Throwout Bearing woes... [Re: Chipper] #231525
01/20/12 06:46 PM
01/20/12 06:46 PM
Vancouver, WA
ChatMaster - 9,000
Vancouver, WA
Chipper is correct and caught the wrong clutch througout bearing sleeve. The sleeve must be smooth on the mating surface without the ridge. Get the proper sleeve and you will be good to go.
devil Agrin
Re: Throwout Bearing woes... [Re: AntiqueMechanic] #231528
01/20/12 07:42 PM
01/20/12 07:42 PM
denver
3
3rdowner Offline OP
3rdowner  Offline OP
denver
I totally agree with the theory of operation, the sleeve needs to be flat and the bearing needs to be clamped into the collar. I am amassed that I have a totally custom set-up, not because it works, but rather, because it appears OEM in every sense. Is it likely that I have an early model Chevy clutch set-up? (490 perhaps)?
Re: Throwout Bearing woes... [Re: 3rdowner] #231531
01/20/12 07:59 PM
01/20/12 07:59 PM
Norway
Bluezone Offline
Bluezone  Offline
Norway
I have some of this Throwout Sleeve .
The 25-26 repair manual show this sleeve.
The split collar come in 1927
Re: Throwout Bearing woes... [Re: Bluezone] #231536
01/20/12 08:19 PM
01/20/12 08:19 PM
denver
3
3rdowner Offline OP
3rdowner  Offline OP
denver
Wow, that is exactly what I have, a cup on the sleeve, and no clamp on the collar. I be darned!
Re: Throwout Bearing woes... [Re: 3rdowner] #231545
01/20/12 10:27 PM
01/20/12 10:27 PM
Vancouver, WA
ChatMaster - 9,000
Vancouver, WA
If you get enough bodies involved you will eventually ferret out the correct answer.
devil Agrin
Re: Throwout Bearing woes... [Re: AntiqueMechanic] #231551
01/21/12 12:48 AM
01/21/12 12:48 AM
denver
3
3rdowner Offline OP
3rdowner  Offline OP
denver
This is why I keep coming back, great source of historical information!
Re: Throwout Bearing woes... [Re: 3rdowner] #231573
01/21/12 04:00 AM
01/21/12 04:00 AM
Chipper Offline
Chipper  Offline
Several of us learned something new today.
Moderated by  AntiqueMechanic
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
1 registered members (swedechev), 6 guests, and 4 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
Truck1927
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
FB_Tweed, Dones475, aland, Stickdude, Achipmunk
15124 Registered Users
Forum Statistics
Forums69
Topics49,997
Posts362,511
Members15,124
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
