Hi,
Do any of the Aussie owners have a spare l/h tail lamp mounting arm they want to sell?
The fillingstation sells LH and RH reproduction tail light arms for 1931 and 1932's, however an Australian 1931 has arms which are 14" long, and the US versions are only 9 3/8" long, so you would need to cut and lengthen it if you have the 14 inch arm on your car already.
JACK
Thanks Jack,
I knew about the FS ones, but not about the length. I'll check mine.
Freight from the US is a bit high, even though the Aus $ is good.
Cheers!
