Posts: 30 |
My 41 Chevy Special Deluxe has a block Casting Number of F0905A just behind the distributor and has 4 screws that hold the valve cover to the head, one in each corner. Anyone know what engine year this is?
Gary 1941 Chevy Coupe Oklahoma Some Where VCCA# 47748
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
If you are looking up information, that is actually not a casting number but more of a production number. That number will probably yield some information for you.
The casting numbers are cast in and are raised not stamped. There will be one on the block and one on the head. They will give you some more information on what you have.
Posts: 30,700 Likes: 141
Posts: 30,700 Likes: 141 |
F = engine made at Flint plant 0905 + month and day engnie was built (Sept 5) A = 235 stick shift passenger car engine does not indicate year as this code was used from 1957-1962. As mentioned you will need the casting number which is behind the starter and starter must be removed to see. If the valve cover is removed the type of rocker arm shaft oil connector will determine if it is a 1958 or older engine or a 1959 or newer, If the side push rod cover is removed and an oil line is seen (lower to the rear) its a 1957 or older engine.
Posts: 30 |
Thanks, it sure is nice to have access to folks with a wealth of old car knowledge.
Posts: 264 |
Topics59,071
Posts429,077
Members18,308
