Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
radiator fluid #231363
01/19/12 05:02 AM
01/19/12 05:02 AM
covina cal
stanman Offline OP
stanman  Offline OP
covina cal
I will be starting this 1931 chev coupe soon.
The radiator has been re-done and tested, but has not been filled in a few years.
What coolent to water mix should I start with?
Thanks Stanman
earlychevguy
Re: radiator fluid [Re: stanman] #231365
01/19/12 05:22 AM
01/19/12 05:22 AM
Iowa
Uncle Ed Offline
Uncle Ed  Offline
Iowa
I always run 50/50 antifreeze and water. If you just want to check for leaks, plain water would be fine as long as it is above freezing which I would think it is in Ca. After you are sure there are no leaks, I would run at least some antifreeze as it has some desirable additives such as anti rust but in Ca. you might not have to run 50/50, maybe 30/70.
Ed
Re: radiator fluid [Re: Uncle Ed] #231378
01/19/12 10:31 AM
01/19/12 10:31 AM
Goulburn Australia
tonyw Offline
tonyw  Offline
Goulburn Australia
I always test fill and initial warm up with straight water then completely drain and fill with anti freeze/ anti corrosive when I am sure there is no leaks.
Re: radiator fluid [Re: tonyw] #231393
01/19/12 02:23 PM
01/19/12 02:23 PM
NC usa
4
41specialdeluxe Offline
NC usa
Just go with 5050. Don't mix your own. By mixing your own, you won't know what you've actually ended up with over time. Savings realized by mixing your own are not worth the extra effort and, sometimes, at least, better water. dance
As to leaks, just have a pail handy and slip it underneath the leak. Merely strain it after the leak is taken care of.
Note: Those in Tennessee and around Cincinnati may opt for the more handy lard stand or wash tub. Just make sure the bath water is out of the tub. monkey Grin.
Re: radiator fluid [Re: 41specialdeluxe] #231434
01/19/12 07:22 PM
01/19/12 07:22 PM
Central Texas
MrMack Offline
MrMack  Offline
Central Texas
Do it the way that is best for you, however I mix my own, since I have 3 trucks, three cars, a tractor and a Kawasaki liquid cooled Mule, I realize quite a bit of savings each year
I have found that “bargain brands” of anti-freeze coolant already mixed 50-50 doesn’t always check out as they should, kind of light on the anti-freeze part. Charlie probably doesn’t have to worry as to whether the mixture is 35 degrees below zero or 10 degrees above zero, but some of us do. Granted pre-mixed or full strength anti-freeze will deteriorate after several years of being stored. It isn’t hard to mix and you can be sure you are getting a correct 50-50 mix. Buy 2 gallons of antifreeze and 2 gallons of distilled water I never put tap water into a radiator or a battery. Distilled water sells for less than $1/gallon, pour them into a clean 5 gallon bucket, (one gallon of each at a time), mix and pour into the radiator using a funnel repeat, and what you have left if any, pour into one of the antifreeze containers and use a black Sharpie marker to label the container the date that it was mixed, stick it in the trunk for use on the road. While you are buying the distilled water get a couple of extra gallons to use as battery water.
Re: radiator fluid [Re: MrMack] #231446
01/19/12 09:20 PM
01/19/12 09:20 PM
Vancouver, WA
AntiqueMechanic Offline
ChatMaster - 9,000
Vancouver, WA
All good information and suggestions.
devil Agrin
Member Chat Group - Non-Geographical Region
Re: radiator fluid [Re: MrMack] #231456
01/19/12 10:25 PM
01/19/12 10:25 PM
Helena Mt
G
glyn Offline
glyn  Offline
G
Helena Mt
If you mix your own as stated then you will always have premix on hand and the coolant in the radiator will always be 50/50. draining and refilling with non diluted can cause variations in the degree of protection.My water faucet provides cheaper water than the stuff i premix as there is no freight and additional profit added. talk
Re: radiator fluid [Re: glyn] #231470
01/20/12 12:19 AM
01/20/12 12:19 AM
merrimack nh
m006840 Offline
m006840  Offline
merrimack nh
I would recommend distilled water as previous post unless you have tested you water supply and it is comparable.
Moderated by  ken48
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
1 registered members (lachlan31), 4 guests, and 5 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
No Birthdays
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
aland, Stickdude, Achipmunk, centercut, Ilike461019
15122 Registered Users
Forum Statistics
Forums69
Topics49,974
Posts362,381
Members15,122
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
