Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
Engine Block Casting Number #231357
01/19/12 03:59 AM
01/19/12 03:59 AM
Oklahoma
snowball41 Offline OP
Oklahoma
My 41 Chevy Special Deluxe has a block Casting Number of F0905A just behind the distributor and has 4 screws that hold the valve cover to the head, one in each corner. Anyone know what engine year this is?
Gary
1941 Chevy Coupe
Oklahoma Some Where
VCCA# 47748
Re: Engine Block Casting Number [Re: snowball41] #231380
01/19/12 11:21 AM
01/19/12 11:21 AM
Bracebridge Ontario,Canada
O
old216 Offline
old216  Offline
O
If you are looking up information, that is actually not a casting number but more of a production number. That number will probably yield some information for you.
The casting numbers are cast in and are raised not stamped. There will be one on the block and one on the head. They will give you some more information on what you have.
Re: Engine Block Casting Number [Re: snowball41] #231418
01/19/12 05:00 PM
01/19/12 05:00 PM
West Allis,Wi.
Chev Nut Offline
Chev Nut  Offline
West Allis,Wi.
F = engine made at Flint plant
0905 + month and day engnie was built (Sept 5)
A = 235 stick shift passenger car engine
does not indicate year as this code was used from 1957-1962.
As mentioned you will need the casting number which is behind the starter and starter must be removed to see.
If the valve cover is removed the type of rocker arm shaft oil connector will determine if it is a 1958 or older engine or a 1959 or newer,
If the side push rod cover is removed and an oil line is seen (lower to the rear) its a 1957 or older engine.
Chevgene
Re: Engine Block Casting Number [Re: Chev Nut] #231506
01/20/12 04:02 PM
01/20/12 04:02 PM
Oklahoma
Oklahoma
Thanks, it sure is nice to have access to folks with a wealth of old car knowledge.
Gary
1941 Chevy Coupe
Oklahoma Some Where
VCCA# 47748
Re: Engine Block Casting Number [Re: snowball41] #231623
01/21/12 06:38 PM
01/21/12 06:38 PM
The New Forest, Hampshire, UK
O
Oracle Offline
Oracle  Offline
O
My index page will give you I hope a decode on the casting number:
http://clubs.hemmings.com/clubsites/chevytalk/GMhistory/index2.html
Moderated by  37Blue
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
0 registered members (), 1 guest and 4 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
Truck1927
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
FB_Tweed, Dones475, aland, Stickdude, Achipmunk
15124 Registered Users
Forum Statistics
Forums69
Topics49,997
Posts362,511
Members15,124
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
