Posts: 173 |
I wonder if anyone can help me. I am wishing to purchase new chev coach bolts (this is what they are commonly known as in NZ, USA may use a different term. The bolts I require are the ones that go between the engine and the front engine mount, and the two that retain the radiator lower frame to the chassis. Cheers Paul
Posts: 825 |
Hi there Paul, coach bolts are the same all over the world. Your local hardware stocks them, all sizes, just measure up and see what's available.... coach bolt: dome top, under that is square head to the bolt shaft. that's it, nothing more mate. Bunnings have an excess of everything bolt'y
Peter
never give 100% unless you are giving blood.
Posts: 29,848 |
Posts: 825 |
hi there, I think that the "Queen" would call them that as well, but I am just a poor little "commoner" ......sob
Topics59,072
Posts429,076
Members18,308
