Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
1924 Superior lifter oil leak #231043
01/16/12 02:50 AM
01/16/12 02:50 AM
Lawrenceville, GA
Dave39MD Offline OP
Dave39MD  Offline OP
Lawrenceville, GA
I noticed the fourth lifter from the firewall has an much more oil coming up from the crankcase than the other lifters. Hard to quantify but after ideling a few minutes it was down the side of the motor and a 3 inch spot in the drip pan. The motor runs great so I am wondering if this is going to be a problem and what the cure might be.
The Filling Station 1912-28
Re: 1924 Superior lifter oil leak [Re: Dave39MD] #231055
01/16/12 05:05 AM
01/16/12 05:05 AM
Vancouver, WA
AntiqueMechanic Online happy
AntiqueMechanic  Online Happy
ChatMaster - 9,000
Vancouver, WA
It is obvious that both the lifter and the bore is badly worn. Lifters are made in oversizes, the problem is to find the oversize.
Hope someone else has faced this problem and has a suggestion.
devil Agrin
Member Chat Group - Non-Geographical Region
Re: 1924 Superior lifter oil leak [Re: AntiqueMechanic] #231099
01/16/12 08:29 PM
01/16/12 08:29 PM
Sydney, Australia
C
chevguroo Offline
chevguroo  Offline
C
Sydney, Australia
A mate of mine many years ago had a similar problem with his 27 Chev. Unfortunately he passed away about 15 years ago. He fixed the leaking by glueing a small length of round tube that was a bit bigger diameter than the lifter, onto the block so that the tube went around where the lifter comes out of the block. Inside the tube he put an oil seal, from memory it was from a Datsun 180B, and never had another leak.
BTW He also fitted 4 wheel brakes to the 27 and had the 'engineered'
Chris
Re: 1924 Superior lifter oil leak [Re: Dave39MD] #231128
01/17/12 02:34 AM
01/17/12 02:34 AM
Lawrenceville, GA
Dave39MD Offline OP
Dave39MD  Offline OP
Lawrenceville, GA
Thanks for the replies, interesting fix! It does seem strange that only one lifter would be worn to leaking. Could it be that the crankcase splash is more intense near this lifter (4th from firewall)?
Re: 1924 Superior lifter oil leak [Re: Dave39MD] #231133
01/17/12 02:57 AM
01/17/12 02:57 AM
The Great State of TEXAS
Chipper Offline
Chipper  Offline
I suspect that there is some pressurization of the crankcase or the splash is directed to the bottom of that lifter. Either of those will help force oil upwards past the lifter. Gravity will try to pull the oil downward.
Re: 1924 Superior lifter oil leak [Re: Chipper] #231319
01/19/12 01:27 AM
01/19/12 01:27 AM
australia
R
rusted Offline
rusted  Offline
R
australia
Hi,
Has the oil filler cap been changed?It should have perforated holes in it for the crankcase to breath.If it is a solid cap,crankcase pressure will force the oil out.
Re: 1924 Superior lifter oil leak [Re: rusted] #231328
01/19/12 02:12 AM
01/19/12 02:12 AM
Chipper Offline
Chipper  Offline
Good point the '28 was the first to use the solid cap as the crankcase vented through the carburetor air intake.
Re: 1924 Superior lifter oil leak [Re: Dave39MD] #231354
01/19/12 03:46 AM
01/19/12 03:46 AM
Lawrenceville, GA
Dave39MD Offline OP
Dave39MD  Offline OP
Lawrenceville, GA
I checked the cap and it is vented but there is a piece of dense foam in the cap which is saturated with oil. should the cap vents be open with no filter or is the foam okay?
Re: 1924 Superior lifter oil leak [Re: Dave39MD] #231361
01/19/12 04:50 AM
01/19/12 04:50 AM
Chipper Offline
Chipper  Offline
As long as the foam is open enough to allow free air movement then all should be okay. If it presents a restriction then pressurization of the crankcase is possible. The amount of blowby is also a factor.
Re: 1924 Superior lifter oil leak [Re: Chipper] #231367
01/19/12 05:43 AM
01/19/12 05:43 AM
australia
R
rusted Offline
rusted  Offline
R
australia
Hi,
When I drive my 27 over 42mph,I get a mess inside the engine bay from oil fumes up the oil filler pipe.
Previously on the old motor before the rebuild,it had a 1/2 pipe fixture on top of the oil filler tube and a length of rubber tube fitted which dropped the fumes out under the engine bay splash pan,similar to the large trucks and tractors.
When I rebuilt the motor I took all that off and used the perforated cap,but was getting the mess so I put the cap and pipe back on.
The cap is a proper made unit,not a cocky job.Perhaps a aftermarket unit.
Re: 1924 Superior lifter oil leak [Re: Dave39MD] #231631
01/21/12 08:44 PM
01/21/12 08:44 PM
Lawrenceville, GA
Dave39MD Offline OP
Dave39MD  Offline OP
Lawrenceville, GA
I had a chance to run it without the foam and the oil stopped running out of the lifter. It still welled up around it but did not run down the motor. No real mess coming out of the oil fill tube. My parts book does not indicate a gasket or filter which seems a little strange considering the roads of the day.
Thanks for the help.
Re: 1924 Superior lifter oil leak [Re: Dave39MD] #231636
01/21/12 09:32 PM
01/21/12 09:32 PM
Sydney, Australia
C
chevguroo Offline
chevguroo  Offline
C
Sydney, Australia
On a lighter note an ingeneous elderly mate places an old sock over the oil filler cap on his 27. It catches the oil, and being a cocky (old farmer) who never throws anything away, he rings the oil out the sock back into the engine so there ie no wastage.
Chris
Moderated by  AntiqueMechanic
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
3 registered members (AntiqueMechanic, lachlan31, Junior_Stock), 4 guests, and 5 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
No Birthdays
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
aland, Stickdude, Achipmunk, centercut, Ilike461019
15122 Registered Users
Forum Statistics
Forums69
Topics49,974
Posts362,381
Members15,122
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
