Posts: 106 |
What would the resistance be for the in-tank fuel sending unit in a 34 Chevy 3 window coupe?
Would it be the standard GM 0-90ohm?
33Master5W 34Master3W
Posts: 106 |
The reason I'm asking is that I have a late model 0-90 ohm gauge in the dash and it appears that an empty tank displays as 1/2 full and when the tank is full..the gauge displays way beyond the full mark.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I would not be surprised if I am corrected but I think the sender unit from factory was about 30 ohms. This being the case I would suggest that there is extra resistance (bad connection) in your system causing a false reading. Tony
Posts: 106 |
Thanks tonyw
Found a link that indicates the pre 65 GM were 0-30 ohm sending units. Just topped up the tank and the resistance is now 37 ohms at the tank.
I may just try increasing the inline resistance via RadioShack.
