#193882 01/03/11 05:00 PM
What do you guys do for 1930 sedan radiators when both tanks and core are bad? Has anyone used those aluminum radiators that is on ebay? Thanks for help! Dale
orgcrate #193947 01/03/11 09:49 PM
I don't know anyone that has used one of the aluminum radiators. Can speculate that they should work but don't know if the inlet and outlets will line up as they are essentially built for V-8 engines.
orgcrate #194076 01/04/11 10:07 PM
Dale, I sent you a PM.Frank
