#182382 09/02/10 07:51 PM
GreggD Offline OP
Does the Pitman arm require some type of puller to release it from the Pitman arm shaft?
Yes!
Hi GreggD,
I needed to use a wheel puller, some penetrating oil, and a small hammer to get mine ('30 Coupe) to come off initially (after maybe 70 years of being originally put on). Since then, it comes off a lot easier. Not that I have to remove it very often.
Dan
GreggD Offline OP
Thanks Dan!
GreggD Offline OP
Thanks Oldie!
