Posts: 30 |
Hi,
I have a '65 Impala Convertible that has just completed a frame-off restoration. As a matter of fact, it's still waiting at the body shop for me. It didn't start out as a frame off, but once they got into it, the frame was starting to rust and had to be beefed up, so it ended up being one. I replaced most of the chrome and emblems including the grill, headlight eyebrows, headlight bezels, both hood and trunk emblems, wheel-well moldings, rocker panel moldings, etc... The ones I have were in pretty good shape, but I figured as long as I went this far, I might as well replace everything. Anyway, when I was in there about a month ago, the front windshield molding was on, and the top piece has a good sized ding in it (looks like a baseball may have hit it at some time). The guy said that he thought I was going to replace it, and I said that I couldn't find the molding for a convertible. The only molding I could find said it was for a hardtop only. Can anyone tell me what the difference is between the convertible moldings and the hardtop moldings? Does anyone know if there are any convertible moldings available? I'm pretty excited about getting it back, although it wasn't a cheap process. The only negative about the car is that the engine has been changed. Somewhere along the line, someone put a 350 in it, but it runs real good. Maybe someday down the road I'll find a 327 for it. Thanks for any replies.
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
Are you talking about the large trim that the convertible has, which goes all the way over the top. It is a unique piece for the convertible, but is common from 1965 to 1970 convertibles. It is the only piece wide enough to have a base ball size ding.
There is smaller trims that are installed after the windshield is installed to fill the last 3/4 " gap. The side trims on the convertible are about an inch shorter , but i think that the upper trim is only about 1/8 inch shorter to allow for the side vertical stainless mouldings.
You may have to have the large trim repaired (if it is dented), which can be done since it is made from stainless steel, and repolished. They do come up on ebay (used) every now and then, but tend to be expensive.
JACK
Posts: 350 Likes: 1
Posts: 350 Likes: 1 |
If it is the Large Molding as mentioned above, send me a PM if you are still looking for one. I have the Windshield Trim available too, but if they are the same or usable from a Hard Top car, they are now available new, altho probably only as a complete set and not separate.
Bill
Posts: 30 |
Yes, it is the large piece that goes across the top windshield frame. I just looked at my '65 sales brochure and figured out that on the convertible it is wider because it has to cover the windshield frame while on the hardtop, the roof is there, so it is more narrow.
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
i assume the trim piece with the dent in it is stainless steel and if so, its not a problem to remove the dent and polish the stainless trim.hemmings has folks that can do the job for you if you lack the needed tools. good luck,mike
Posts: 30 |
Bill, My plans are to pick up the car on Friday. I'll double check then, but I'm sure it's the long wide piece that goes across the top. If I decide to replace it, I'll be in touch. Otherwise, I may just try to take the dent out myself and polish it up.
when removing the dent, lay the moulding on an anvil or large thick piece of oak. don't attermpt to remove the dent in just one blow of the ball peen hammer. rather use munltiple gentle blows to return to the original profile. don't overstretch the metal. once its close, gently sand the marks made by the ball peen hammer. i use 150 grit for the initial sanding then go to finer grit paper (300 then 600) . to finish off the stainless, use 3M Trizact Hookit II which will negate the need for an expensive buffer and buffing compound. these new 3M products almost eliminate the need to use the Baldor buffing machine. good luck,mike
Posts: 30 |
Thanks alot, Mike for the advise. I was hoping someone would chime in with some "how to" instructions. We'll see what happens. Thanks again.
Randy
Posts: 30 |
Hey guys, sorry it took so long to get back to this post. Well, I was wrong about which trim piece it is. It is NOT the large wide piece that goes over the top of the windshield frame. It IS the top piece that fills in the windshield gap. I believe it measures about 1/8" wide. Does anyone know how this piece comes off? Would anyone have one of these laying around? Would this piece be different on the hardtop models or would the same piece work on the convertible? If I can get it off, I may just try to pound the dent out and see how it looks, unless someone has one they want to get rid of.
The 3 piece trim which covers the windsheild is held on with spring clips. there is a tool ilustrated in the 1965 body service manual. It is 1/16" flat steel with a 90 degree tapered point hook on the end. It slides on the glass and under the trim, disengages the clip, and the trim then comes off.
It is the same trim as the hardtop, only about 3/16 inches shorter.
JACK
Posts: 30 |
So would the hardtop trim work on the convertible?
Yes, it should work, but you will have to trim it down, as the convertible trim is shorter due to the stainless side trims.
JACK
Posts: 350 Likes: 1
there is a tool ilustrated in the 1965 body service manual. It is 1/16" flat steel with a 90 degree tapered point hook on the end. It slides on the glass and under the trim, disengages the clip, and the trim then comes off. If anyone out there knows where a picture of one of those Factory Trim Removal Tools would be, I sure would like to check on one. Or if someone could suggest an alternative tool that would be just as good. I can usually get trim off without too much trouble, but I have run into a couple lately that were hard to get out without damaging. Bill
I have emailed a picture to you Bill.
JACK
Posts: 350 Likes: 1
Jack,
I got the picture, thanks, sure do appreciate it.
Bill
1 members (Oldiron),
79
guests, and
16
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
