#117705 03/17/08 08:51 AM
Drew22 Offline OP
Did any of the Chevelles come with a Hurst 4 speed shifter from the factory? I know most came with either Saginaw or Muncie shifters that many then switched out for Hurst. The reason I ask is I have a 70 Chevelle restored to factory specs with a Hurst shifter and wanted to put an emblem that you see on some GTO's that says "Hurst Equipped" but I don't want to add this unless some Chevelles actually came with Hurst shifters.
Wilwood Engineering1955-1957
I also had a 1970 Chevelle with a #s matching 454 4 speed
that had a hurst shifter.Sorry can't tell you if it was factory
or not.
Dan
