58 Impala motor oil and transmission leaks - 07/09/09 10:28 PM
Just now putting the Impala back on the road after 23 years of delay!! Checking the drip pan under the car I found a lot on motor oil and transmission fluid. The motor had leaked out about l 1/2 quarts and the tran fluid was over 3 quarts low. I filled up both items and started the car. After running for about 10 minutes, I turned off the motor. The next day, there was new oil and transmission fluid in the drip pan. I started the Impala again and drove it arround the block. I stopped and checked for leaks again, but didn't see any. Will the seals stop leaking for the most part or will I need to reseal both items??
