dads51 -
Probably more than you ever want to know about gasoline filters. I believe the information to be accurate. Please let me know of any errors.
What year is your vehicle, I assume a 1951? Is it a passenger car or truck?
Your filter and fitting look like a dealer installed GM Durex Moraine 986640 Gasoline Filter on a Chevy truck. If it's a 1951 truck, then it is perfectly period correct.
The angled fitting is 60-deg and was supplied for 1950-1954 trucks and 1953-1954 sedan delivery.
> 1929-1954 MPC - Group 3.890> Installation instructions in the 1954 Acces Inst ManIf you need a cork gasket, I posted links to patterns ...
> in this VCCA Chat threadIf you need a bronze filter element, they sometimes appear on ebay.
Durex Moraine filters were produced by GM and installed by dealers, plus sold as aftermarket filters for most vehicles.
GM offered a Durex Moraine #986128 gasoline filter as an accessory installed by the dealer 1947-1949. There was a different part number for a similar filter. I can't find the number and don't know if there were differences or if it was just packaged with different fittings. The filter had a glass bowl with a winged thumb screw through the bottom of the bowl. The filter element was porous metal. It's pretty cool looking.
> Durex 986128 gasoline filter - April 1949 Motor Age adAlthough this photo is in the 1951 Accessories Installation Manual, GM did not produce the filter in the pic after 1949. Durex Moraine #986128
> Pre-50 filter in '51 Manual> Chevrolet Accessories for 1948 "Filter Unit - Gasoline" #986128 (price for 12 filter units)
> 1949 Chevrolet Accessories Brochure "Gasoline Filter Unit"
In 1950 GM changed the design to a glass bowl with a bale and thumb screw. Durex #986399. I have read that a special 60-deg fitting was included with the filter in 1952 to allow it to clear the automatic choke on a Power Glide passenger car and the number was changed to 986640. I can't confirm the reason. The fitting is shown on the truck installation instructions. Trucks did not have PG transmissions. I don't know of any modern supplier that sells the 60-deg fitting.
> Durex #986640 in 1953 ad> Durex #986640 on my '54 3104 (incorrect 45-deg fitting)
I don't believe that GM offered an accessory gasoline filter in 1955, except for 1955 1st-series trucks.
1955 1st Series Trucks Accessories
"Filter, Gasoline" 3100, 3600, 3800, 4000, 6000
No part number or price
> 1955 GM Resto KitA GM AC #987500 filter was offered in 1956. In 1957 the filter was changed to accy number 987629 (with fittings) or 854345 - bare filter only. I'm not sure which of the filters was the glass bowl filter with a flat metal top, or which was the glass bowl filter with a dome metal top.
1956 Passenger Car Accessories:
Filter Unit - Gasoline All Exc 3400, 3500, 3700
#987500
$2.35 each Suggested List, $1.41 Dealer net
> 1956 Passenger Car Accessories1956 Truck Accessories:
Filter - Gasoline (Use with 8,000, 9,000, 10,000
#987500
> 1956 Truck Accessories> Filter 1929-1957 MPC - Group 3.890And if this has not been gasoline filter overload, then here is a thread by Chevgene and others that tells even more!
> VCCA Chat threadGood luck with your filter.
- Lonnie
