38 Master Temp Gauge Probe Leak - 10/18/22 03:05 AM
Hello
If it isn't one thing, its another. While fighting to get my Carter W-1 working properly I have another issue that won't go away. The prior owner ran the the heater hose to the top of the block as well as placed the shutoff valve there too. I was told that it was incorrect so I moved the newly purchased shutoff valve and heater hoses to the water pump area.
-The problem: coolant keeps leaking from the fitting despite using teflon to seal any possible leaks. I purchased a new fitting to the block from chevsof40s or Filling station(i buy form both to support them). I found the original fitting I didnt know i had and wonder if the mating between the original fitting and the probe nut will fit better than the reproduction? Am i just doing something simply wrong?
-Attached images are one of a similar probe that has the probe nut and shaved sides like mine(not sure why they are shaved) and my installation
Thank you
Michael
38 Master sedan
Thank you
Michael
38 Master sedan
