Headlight Headaches - 07/10/23 06:10 PM
I have a 1937 1/2 ton pickup that is basically original except that it was converted to 12 volt when the original harness (which was in shambles) was replaced. The headlight buckets and wiring system are the same as original except for using 12 volt bulbs. Here’s the problem: the passenger side headlight shines strong and bright, but the driver’s side headlight shines at about 1/3 the brightness of the passenger side. I’m assuming that this is some sort of grounding problem or a bleed of some sort.
If you have ever worked on a 37 or 38 truck headlight, you know that it’s a major hassle to remove the headlight bucket and or stanchion to get to the underside of the light where the harness enters the bucket (the radiator and stand are in the way, along with portions of the grille shell, etc.).
My question is whether there is a solution to my problem that can be achieved by working through the front of the headlight, i.e., by removing the headlight rim and lens, and reflector if necessary, without having to remove the entire headlight bucket from the grille shell? Any suggestions will be welcomed. I don’t drive the truck at night very often, but it would be nice to have both headlights working equally well.
Thanks in advance for your help.
Jim
Jim
