Brake lights keep blowing fuses - 05/26/19 06:22 PM
I have a 33 Master Coupe. It keeps blowing 10 amp brake light fuses. It seems like if anything metal touches the outside of the brake light switch the fuse will blow. It doesn't make sense because the switch itself is attached with a bolt and is grounded. I have taken the switch apart and everything looks good inside. It doesn't look like anything inside the switch could short out against the casing.
Dennis
Dennis
