I have been using a fuel pump that was new or rebuilt so long ago that I doubt ethonal was even thought of as a fuel suplement.
Hawkeye, I recommend you stick that sucker in and forget about it.
The scare tatics about ethonal just keep on a-coming.
Charlie
BTW: I don't understand your inability to add anti-freeze. Merely open the petcock at the bottom of the radiator and the opening at the lower rear of the block. Catch the fluid coming out and, if clean, you can add it to the anti-freeze. The 50-50 will flood the innards of the engine. Close the petcock and valve when done and forget it.
