1929 Chevy Clutch/Flywheel Issues - 01/23/24 11:04 PM
Hi everyone, I have a 1929 Chevrolet Imperial Sedan, 194 c.i., 6-cylinder, 3 speed. This car is being re-assembled after frame was powder coated and remainder of parts cleaned, coated, painted as necessary. I’m having problems getting the clutch to function - clutch doesn’t move. When all 3 components are assembled the throw-out bearing sleeve sticks out only 5/16" from the pressure plate. Here are the part numbers and pictures of what I have. Any help getting clutch operational or knowledge regarding part compatibility would be greatly appreciated.
Flywheel:
Part Number 835767
Date Code E 27 9
9 3/16" Machined, Recessed Surface
Clutch Disc:
Aftermarket
9" Diameter
Pressure Plate:
Part number 835821
10" Surface
Flywheel:
Part Number 835767
Date Code E 27 9
Clutch Disc:
Aftermarket
9" Diameter
Pressure Plate:
Part number 835821
10" Surface
