I have isolated a weak spark problem to be the coil by hot-wiring directly from the battery to the coil and then to the points with a condenser to ground. The coil lasted 250 miles before the spark became too weak to start the engine. The ohms measured 1 ohm primary and 9k secondary, however, the amperage draw according to the dash meter was -8 amps and the repair manual says if it draws more than -3 amps to replace the coil. I ordered a new one and it also measured 1 ohm and about 7k ohms and the ammeter indicated -6 amps the spark was great, nearly one inch long so I put the system together and planned to start it up. Then it occurred to me that I hadn't checked the spark at the points before putting the distributor cap on, so I checked the points by opening them and found the spark was not that hot. I went back to the hot wire system that had given me the hot spark and now it was very small and weak, and the ammeter indicated -9amps. I believe the new coil is now shot also. My question is what brand of coil do you use or recommend? I did buy from one of our suppliers. I am considering ordering a Model A coil, however, I don't know if it would fit in my bracket. Also, to be sure there was not another drain on the system I checked the ammeter with the coil disconnected and the ammeter did not move.
