OK... I need your advice ... about how to time this 1934 master, without cranking it with the starter or turning the engine over.... New wiring, rebuilt carb, New gas tank & battery.... All clean down to shiny metal connections... new, good ground straps.... the motor turned over, almost fired... Getting gas & spark.... but sounds like the starter is dragging a little, as it cranks..... The distributor was PULLED, to turn the new gear drive oil pump with a drill... to get the oil flowing first..... I marked the distributor when I pulled it ... with the rotor position..... But I probably got it back in wrong..... I Think the timing is off..... I CAN'T crank it... to put a timing light on it.... and I pulled the plug out of # 1 cylinder... and poked a screwdriver down the hole to see if I could feel the piston coming to TDC... BUT couldn't touch the piston top..... Oh well..... How do I time it... without running it..?? Even with the 6 volt battery charger on it... it will not crank over the motor..... the starter was cranking it over for about a minute... while I pulled the choke... and tapped the gas ..it did fire a few times.. NOW .. even with the battery all charged up (6.73 volts).. and the charger on it... the starter will not turn..... the solenoid just clicks.. but won't turn the starter... So... It was cranking fine but sounded slow and just stopped.... would it help to get the timing as close to right as possible.. to eliminate the drag it would place on the starter... or should I pull the starter off (keeping the wires connected)..... and the try to hit the starter button and spin the starter ... while off ??
