Hi Matt,well,I have never had to repair your exact problem,but I did have a fuel leak in an old Iron Horse tractor fuel system.Grant it,it was diesel fuel but I mixed up some JB Weld and,after cleaning the surface around the crack in the metal with Brake Clean,I worked the JB into the crack,wiped off the excess and that was the end of the leak. It is gray in color and you cannot even see it in the crack. It is on year 7 and still holding tough. Maybe not for the perfectionist,but got the job done fast and easy.....Best of luck Matt..
