Posts: 2,433 |
When I had my 48 216 rebuilt a few years ago, the block and head were baked clean by the machine shop. I really don't know much more about the process than you mentioned Joe, but I haven't had one bit of overheating since the rebuild. I run a 160 thermostat and the highest temperature I've seen was 190 while idling for about 1/2 hour in 85-90 air temp. and it dropped right back down as soon as I started driving again. Apparently the "boiling out" process has become a waste disposal problem environmentally and has been replaced by "baking".
ken48 VCCA 42589
Often the flushing of the system will be necessary will be necessary again in a few months due to more rust loosening up from the bottom of the water jackets.It almost impossible to get all the rust out without have the block boiled out. The 1941 and up Chevrolets were rather cool running cars when they were new.If the cooling system was clean they seldom overheated-unlike most cars of those years. I do remember them overheating due to rust when they were just a few years old . The people would drain the anti-freeze. run straight water in the summer,Then put the old anti-freeze back in for winter....and the anti-freeze did not contain rust inhibitors as todays mixture.
Posts: 210 |
A great bunch of info guys. Thanks.
'46 Fleetline Aerosedan Most southernest vintage Chevy owner in Canada.
