Early Findings: 1) Your
Chat user number is now ONE LARGER that it was. If you used to be user 114, then you are now 115. It doesn't really make any difference, but the "system" stole my Number One position, so now I'm number two!!!
2a) When you click on
Preview, after you've drafted a reply, the preview
does NOT show your signature line. This is a documented shortcoming of this version.
2b) When you click on
Preview, it shows in the same window,
right BELOW where you were editing. No popup window.
3) You can
VIEW the portal and all postings WITHOUT logging in. But if you want to Reply, or Post a comment, then you have to log in. This will help keep the registration count down a little bit.
4) Notice that you can
add all kinds of colored text, sized text, and other cool things to your postings.
5) You can ask for a
list of all topics that were posted within the past 24 hours (as previously), and within the past 48 hours (NEW), or the past 7 days (NEW).
6) If you
forget your password and prompt the system for help,
it will email you a NEW password which you must use to log in. Then you'll need to go to MyStuff and change it to what you want it to be.
