#90191 08/23/04 12:48 AM
#90195 04/30/05 02:16 PM
Chev 4 cyl casting numbers
Note: I have tried all the tricks in my bag and can't get this to maintain chart grids, so read it carefully and you will figure it out.
Credit is given to Dave Taylor of South Africa for providing this data and permission to post.
CYLINDER BLOCK CASTING NUMBER IDENTIFICATION
Year Model Casting No Part No
24 327772
25 Series K Before February 334653
25 Series K After February 344624
26 Series V & X 345505
27 348709
28 348532
CYLINDER HEAD CASTING NUMBER IDENTIFICATION
17-19 DV8 338048
22 FB Three Port 381099
16-21 333776
21-24 Aug1921 … Nov 1924 327773
24-26 Dec 1924 … March 1926 344128
26-27 Mar 1926 … June 1927 Single Port 1 ½ inch Valves 345453
27 June 1927 onwards Single Port AA LM 1 21/32" Valves 346886
28 Two Port 348540
36-51 With fan (for low speed driving) 602253 604486
48-52 With fan (5” dia. pulley) 1911990
TRANSMISSION CASE,
16-21 14181
25 590204
26 590219
28 590321(F 13 8)
590328
590279 (I 8) 353300
TRANSMISSION CASE COVER
16-21 14182
25 590061
27-28 590281 590034
TRANSMISSION U-JOINT CASE,
16-21
25
27-28 590182
TRANSMISSION SPIGOT SHAFT PLATE
16-21
25
27-28 590211
DIFFERENTIAL PINION,
16-24 Chevrolet, 490, Superior, Passenger & 1/2 ton truck ratio 33-9
ratio 34-9
25-28 Chev. K, V, X (67mm Dia) Ratio 42-11 344025
29 Passenger & 1/2 ton PU, A-6 (70mm Dia) Ratio 42-11 355414
DIFFERENTIAL CARRIER ASSEMBLY,
26-28 344031
DIFFERENTIAL CASE,
26-28 344021
Agrin
#90196 07/25/05 02:47 AM
Originally posted by Oldie:
Okay, The following covers the time frame being discussed.
1 = Flint
2 = Tarrytown
3 = StLouis
5 = Kansas City
6 = Oakland
8 = Atlanta
9 = Norwood
14 = Baltimore
20 = Los Angles
21 = Janesville
In 1953 The serial number system, with reguards to assembly plant identifiers, changed. The 1953 serial numbers looked like this:
53A = Atlanta
53B = Baltimore
53F = Flint
53J = Janesville
53K = Kansas City
53L = Los Angeles
53N = Norwood
53O = Oakland
53S = St. Louis
53T = Terrytown
Over the years the Plant identifiers changed due to assembly plants being added along with the mix that came as a result of GMAD being formed.
A = Lakewood
B = Baltimore
C = Southgate
D = Doraville
F = Flint
J = Janesville
K = Leeds
L = Van Nuys
N = Norwood
R = Arlington
S = St. Louis
T = Tarrytown
U = Lordstown
V = Pontiac
W = Willow Run
Y = Wilmington
Z = Fremont
1 = Oshawa (yes, that's a one)
This information was 'borrowed' from another thread and placed here for the record.
Agrin
#90197 08/09/05 05:47 PM
What a great list.
Michael41
Michael
#90198 04/13/06 03:40 PM
where was serial number on 31 chev 4 dr sedan??
ALLEN MCCALL
