#77652 01/29/02 02:43 AM
Does anyone know what would cause my timing mark to be bouncing around? The truck is 77 crew cab dually with a 69 396 motor with a HEI distributor
World's Greatest
Vintage Chevrolet Club of America
"The World's Best Chevrolet Club"
#77653 02/03/02 09:44 AM
Hi Tim,
There are two things that can cause this.
1) - the mechanical advance mechanism needs some attention in the HEI.
2) - the timing chain is shot! Better take care of this, otherwise it will let go and can cause somes fairly nasty damage.
Also, the outer ring of the harmonic balancer may be loose - causing the mark to "move". This would not appear as erratic movement however, more slowly, the mark would move around the dampner.
Oliver J. Giorgi
1958 Passenger Car
#77654 02/25/02 12:36 AM
Also the most simple the plug wire may be bad. Rock the dampner back and forth and see if you have any slop in the chain.
Restored or rodded just drive so people can see the bowtie .Dont hide it away in a garage for no one to injoy.
