#51487 04/22/02 01:27 PM
GENTELMEN WHEN YOU PUT YOUR AUTO'S IN STORAGE OR NOT IN USE FOR SOME PERIOD! DO YOU SHUT VACCUM TANK OFF AND RUN ENGINE UNTIL ALL FUEL RUN'S OUT OF CARB AND VACCUM TANK ? TO PROTECT UPDRAFT CARB FROM RUSTING OR ROTTING ? JUST WANT TO TAKE OF CARB PROPERLY !!! THANK YOU.
N J HORST
#51488 04/22/02 01:43 PM
I had a problem with fuel evaporating from carb leaving a gummy varnish causing choke to stick on the standpipe. I also had a problem with a 1931 mechanical pump diaphram that cracked after being dry for months. For me the answer has been to start the engine every couple of weeks even in the winter.
If you have old Chevrolets, other old Chevrolets will find out where you live.
