I am electrically challenged. Is there a simple way to test an electrolock?
1932 Chev 5 Window Coupe
What are you wanting to test? The continuity?
Use a multi-meter and connect it as shown below with the key in the on position. If the continuity is good it'll read all 0s. The pictures below are me testing mine following a rebuild.
1 member likes this :
Clement
Check the centre wire for continuity,on off switch, and also check the centre wire for contact with the outer cable.
JACK
All good. Electrolock installed and working. Many thanks!
Great! You are now on the way to being a cracker jack mechanic.
Not sure about crackerjack but we do learn something new everyday, and this forum is certainly a great help.
