In a 1936 Chevy Master, the cooling system circulates water through the radiator and the engine. Overheating issues specifically arise during high-rev situations, accompanied by the development of a misfire. There are two potential culprits I suspect might be causing these problems: a leaking head gasket or rust accumulation in the water jackets.
Furthermore, the overheating tends to occur when the vehicle is at idle for extended periods, typically around 20 minutes, after reaching the working temperature of 180 degrees. It's worth noting that I've taken steps to address this issue, including thoroughly flushing the engine and radiator three times prior to the initial engine start. Additionally, I've confirmed that the thermostat is functioning correctly by testing it outside of the vehicle. any help or references. would be great. coolant is used right now. but changing to just water and a water lubricator/anti rust lubricant
coolant vs water
I just want to get on the road!!!!!
