#486191 10/14/23 11:35 AM
Midi Offline OP
I have built a jig and reamer for line boring the bushings in 49-54 a third arms. I have been asked by another chevy owner if the power steering third arm uses the same pin, bushings, shims, and seals. From what I can see in my parts catalogs, there is only one part number for either the power steering or the standard steering assembly. Therefore I assume the overhaul of the power steering arm would be the same as the standard. Could one of you chevy sages please confirm my wild [bleeped] guess? Thanks for all your help.
Yes, that is correct.
The one that was diferent was the Corvette whcih had bearings.
Midi Offline OP
Thanks again Gene, you are the best.
Midi Offline OP
That is reassuring DRTYLER. I appreciate your response.
as gene noted, the 53-63 corvette 3rd arm has a roller bearing instead of bushings used on the passenger car chevys 49-54. however, if you are fortunate enough to have the corvette 3rd arm laying in your parts bin, it will interchange with your passenger car. and you will never have to worry about worn out bushings common to the pass car 3rd arm. unfortunately, the corvette dealers charge a good deal of $ for the bearing type 3rd arm. mike mccagh
If I am not mistaken, there's more to do than just changing the idler arm. There also a bracket that is needed for Corvette idler arm. I think the tie rods and steering arms must be changed to prevent bump steer.
I have not had experience with this swap but I have been doing some research to make the swap later.
1951 styline deluxe sport coupe w/54 engine and power glide
