#485450 09/15/23 09:45 PM
ttomtt Offline OP
Does anyone have a picture available of a Tri-Power set-up on a 216 motor. I am looking for a picture of linkage on Stromberg 97 carbs.
Thanks, Tom
ttomtt #485510 09/18/23 08:13 AM
Show us the intake! I have several and there all different as to intake or carbs. Sounds like a edmons? Is there anything else done to the engine? I run all of mine with straight linkage, not progressive. This is a original forum not sure if you will get many responses. The Hamb mite get you more replys.
Rooster
ttomtt Offline OP
Thanks, I will get some pictures, no name on the manifold.
ttomtt Offline OP
The only marking is the word chevy cast on the top
ttomtt #485544 09/19/23 09:38 AM
Thanks for the picture.
But with your first post asking about linkage for 97's, I was expecting (hoping???) to see an IR type manifold for three two barrel carbs.
Jon
ttomtt #485553 09/19/23 07:38 PM
Cool intake! What carbking was referring the the Stromberg 97 and Holley 94 are both 2 barrel Ford carbs. You have 1 barrel carbs maby zenith from a Chevy or GMC truck. Also good carbs. The only linkage available is for a duel offenhauser. Speedway motors has linkage and parts and pieces to make one up.
Rooster
