Posts: 325 |
I have a 12-volt system on my '41 Chevy. I am keeping the old gauges. I have put in a reducer to go to 6 volts. How many volts and ohms go to the gas gauge? Do I need to go through the new fuse panel? Or could I just put in an "in-line" fuse? (It was suggested that I bypass the solenoid and go directly to the battery.) Thanks, :confused:
Dan.
See comments on your other posting. The sending unit and your dash unit are designed to operate with 6 volts. The nominal resistance from the sending unit is approximately 30 ohms. It is always a wise idea to fuse every appliance/accessory on the vehicle. If you have a fuse panel that is great, however an inline fuse holder is satisfactory.
Posts: 325 |
Thanks Ray. Appreciate the help.
Dan.
3 members (Tiny, 38chevy, 1 invisible),
75
guests, and
35
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,071
Posts429,069
Members18,308
