Posts: 1 |
before vacation I got the wires (positive and negative) hooked up backwards on the batt. trying to get a C.D. out. Now I can not get the engine to turn over fast enough to get it started. I have had the batt. checked, exchanged starter and sol. , put a new postive batt. cable on and have replaced the wires that goes from the batt. to the switch and the wire from the batt. to the alter. does anyone have a clue of what I should check next. Thanks for your help, may God bless the U.S.A.
Posts: 11,162 |
HVYCHEV sounds strange, what modle of car and electrical system?
and
What was you doing trying to get a Certificate of Deposit out of the car??????
Posts: 64 |
If you reversed the batt cables with an alt you will need to have the alt checked as it will damage it..Check the ground,,then load test the batt or try a different batt..How long was it hooked backwards...doc
doc
Posts: 439 |
Regards,
Jim M.
Topics59,071
Posts429,078
Members18,308
