Posts: 62 |
The generator on my 29 is acting up (read: not charging well) and I was wondering before I have it rebuilt what the pros and cons of switching to an alternator are. Thanks! -dave
Posts: 29,848 |
Switching to a six volt alternator will require a different fan belt and different mounting brackets as well. I would recommend getting your generator rebuilt correctly instead. Once done, your generator and cutout should last almost a lifetime! By the way, the correct generator for your '29 is a Delco-Remy model 943-J.
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
agree with the JYD. stick with the delco generator and have it rebuilt. finding an alternator pulley that will jive with your 29 pulleys(H2O pump and harm. balancer) will be a tough row to hoe. Send the old generator to the JYD--he'll get it going right. mike
Posts: 6,149 Likes: 41
Posts: 6,149 Likes: 41 |
Send the generator and cutout as a unit that way JYD can set it all correctly and you only need to bolt it back on. Tony
2 members (modiol, 1 invisible),
63
guests, and
7
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
