Posts: 3,542 |
The cylinder that the key go into has started to come completely out of the switch if you pull on the key when it is inserted. The switch works ok, but if you pull on the key (except in the 'off' position) the cylinder comes right out.
How do I fix this or do I need to buy a new switch?
Posts: 3,542 |
Thanks JYD, I was afraid of that...
Posts: 3,542 |
Just ordered a new one along with a new headlight switch from Chevy Duty. http://www.chevyduty.com/frame-store.html P.S. They were $10 dollars cheaper than the other Chevy parts places I checked with for the same headlight switch.
Posts: 3,542 |
