Posts: 2 |
I recently purchased a 1925 Chevrolet Model K. It is in great shape. Estate sale. Unfortunately the estate can’t find the ignition key. Any suggestions on getting the ignition out so I can get a key made?
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
I don't know how it translates to a 25 but on my 38 there's a tiny hole in the front of the tumbler. You turn the key to the on position then stick a paper clip end in the hole and push, you'll feel spring tension against the clip, then turn another 1/4 turn and pull it out.
Not at all like the 38.
You can purchase a key from Gary Wallace.
I would suspect the ignition is defective. If you need help I can restore your switch, in fact I can restore any item on the dash except the speedometer.
Posts: 2 |
Thanks! I don’t think it is defective but I will investigate further.
Posts: 487 Likes: 9
Posts: 487 Likes: 9 |
Ray, I too need a key for my 25 Model K Superior. Where can I find Gary Wallace?
John EF Schildberg III
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
In your G&D magazine Parts for Sale section.
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
Gary Wallace St Louis 314-293-1991
Posts: 164 |
How much to rebuild two light switches with the keyed ignition? Eric in Reno, NV (775)440-1774 Thanks
Rusty Junk
Approximately $275 each. Each switch has it's own problems and a firm price can't be determined until it is on the bench.
