Posts: 5 |
Hi, A good friend of mine has converted his 1940 **** p.u. to 12 volt and is having a problem with it quitting when it gets warm, as far as we know all has been done right, changed bulbs, put 12v armature in the generator, 12v coil with external resistor,new condensor,etc. I know it's a **** but we are both Chevy guys too, he also has a beautifully restored 1954 Corvette. Any ideas or suggestions will be appreciated. It acts like something is getting hot and causing the problem but when it bothers the coil feels cool. Thanks John
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
I would replace the condensor first. If that does not do it then check the ignition switch. Finally replace the coil. My experience with those other brand vehicles also suggests to make sure the wire inside the distributor is not grounding against the center shaft. I walked several times until I found that problem.
Posts: 11,162 |
Have you checked the fuel pump, those old flatheads with the fuel pump on top of the engine were very bad to vapor lock
Posts: 5 |
It has an electric fuel pump and we checked for fuel press. beside the road and that was fine, appears to be electrical. How many volts should be at the coil?, we checked this morning and have 13 volts on the batt side of the resistor and 9 volts coming out of there going to the + side of the coil, the side going to the dist has 5 volts, is that too much and possibly heating something up ?
Jump the resistor and take it for a spin. Don't let it idle too long with the resistor jumped as it will overheat the coil. If you decide you have a coil problem, purchase a coil with internal resistor and get rid of a lot of problems and extra wiring. (Jumping a resistor. With a piece of wire connect it to one end of the resistor. Take the other end of the wire and connect it to the opposite end of the resistor.)
Posts: 5 |
Thanks guys, we found it, the generator was not putting out enough, finally during the time messing with it it quit completely we tried jumping the resistor and it ran great with the battery voltage, I guess it needs 14.5 plus volts to the resistor to get enough to the dist., what a difference, I wouldn't have believed that 1-2 volts would make such a difference, Thanks again John
