Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
Does anyone out there know the application of a 943-B Generator. I recently saw them on a 1929 and 1932 Chevrolets. The only difference I could see was the 943-B had the cut out mounted parallel to the pulley and a 943-J mounts parallel to the shaft. I have one but don't know the correct application. I can always use it as a spare for my 1931. Thanks for your help.
See you down the BACK ROADS.
Joined VCCA June 1, 1961
