I have occasionally come across W-1 float bowl covers that have had a small hole drilled in them. I've attached photos of the latest one. Hole is just behind the gas inlet fitting. Any idea why you would drill a hole into the chamber where the gas is? I've always thrown these covers away figuring they were useless or is there some purpose behind this??
Dale Carter
VCCA #8661
1948 Fleetmaster Convertible
1948 RHD Stylemaster Sedan Delivery
1948 1-Ton Tow Truck
1967 Camaro Coupe
In looking for a W-1 for my car I came across this unit on ebay. Looks like what you may be referring to. I am sure there is someone on here much smarter than me to answer your question. https://www.ebay.com/itm/Carter-W-1...48-Chevrolet-216-6-Cylinder/184466339959
The hole was drilled later by a back yard mechanic.....it does not belong there. It usually was done to improve hot weather starting whch it did not do. The vent would throw off the main carburetor feature which was balanced air flow.
Gene
Is that the same story on the one that is on Ebay?
