another problem, noticed last year when I started the 28 up last year .starter drew a lot of juice from the battery so I sent to Wally Deck for a new rebuilt starter figuring my old commutaters needed to be turned down and starter needed a rebuild,his new one would save time.put in new starter and same sittuation occures.very hard starting .When it does start though,the motor runs fine ;no sputterin,buckin or any overheatin I`m baffeled again with this electrical stuff .Much thanks .arent old cars fun$ps: if timing was off a couple of degrees wouldn`t I get the above symptoms?
