Posts: 412 |
Installed grille, rad etc on my '32 car. The fan is quite close to the rad. It's an original honeycomb so I really don't want it damaged! Just wondering what is normal clearance between fan and rad core. I think I have about 3/4".
1932 Chev 5 Window Coupe
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
The closer the fan is to the radiator core the better the low speed heat transfer. 3/4" is okay as long as the fan does not wobble.
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
Chipper, While that may be true, I think poster was asking is whether that distance/gap (from the radiator to the fan) on a 32 is normal, wobbly or not. I sure don't know. The answer is above my pay grade. I'd bet that Chip knows. Best, Charlie
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Sounds about right as it barely leaves enough room to get the belt on.
Correction. I bet that Steve D knows. Best, Charlie
Posts: 412 |
Thanks everyone. No fan wobble. So I guess it should be OK.
