The camshaft front plate area is leaking a lot of oil to the point that is just pouring out of thee timing gear cover.The engine was recently overhauled, the cam was reground. I just learned that the 32 does not have cam bearing. What do you think was done wrong ??. How can I fix the problem. Is there a bushing there, prior to bearings ?. As always; THANK YOU. Hotpockets
Go back to your first post for the info.
