The maximum output position of the 3rd brush on a DELCO-REMY 943-B generator,is no closer the 2 1/2 commutator segments from the + main brush,which is the brush closest to the LH mudguard.The maximum cold output is 16 amperes,8.0 volts @ 1,600rpms(engine revs),or about 25mph.The maximum hot output is 12amperes,7.7 volts @ 1,800 engine rpms,again about 25mph.To reduce the output,loosen the clamp screw slightly and move the 3rd brush arm towards the engine,but not too far,as the 3rd brush arm may come into contact with the top through bolt.
If you still can't get the output down any lower than 12amps,then you may have to look at taking the cutout off the generator,checking the air gaps & point gap,then upon re-installation,you should check the cut-in voltage of the cutout(the voltage needed to close the points on the cutout),which should close somewhere between 7.0 volts - 7.5 volts.A closing voltage any lower than 7.0 volts will cause undercharging and a closing voltage higher than 7.5 volts will cause over-charging.
