Posts: 3 |
Where are serial numbers found on 1932 Chevrolets?
Al Carpenter
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
The transmission serial number is stamped on a machined surface on top near the shifter, the rear end serial number is on a pad on the housing near where the torque tube rivets.
Posts: 3 |
Thanks guys! I really appreciate the quick response.
Al Carpenter
Posts: 3,542 |
What about the cowl tag and its' information?
Posts: 3 |
Good question. As I understand it, the cowl tag identifies the characteristics of the vehicle when it was new. "Paint Number" described the paint scheme from the factory; "Vehicle Number" described the body type; etc. I haven't seen the tag on the vehicle in question but my brother who is looking at it for me mentioned it. I believe he said there were three items but I can't recall the third one. If I'm wrong on this, I'd appreciate it if someone would set me straight.
Al
Al Carpenter
For 1932, the Fisher Body cowl tag had the following information: Job Number Body Number Trim Number Paint Number
