Does anyone know what colors are used in the cloth windings of the spark plug wires of a 1935 Chevy Standard Coach? I have seen black with different color tracers, and tan with different color tracers, yellow with tracers etc. Was there a standard color or did they use what they had at the time? Also I have a question about the length of the coil wire. The coil is only a few inches above the distributor. Was the coil wire a straight shot up to the coil, about 3" long, or is it about 5" or so and bends down around the other wires?
