Posts: 109 |
Hi All; do the 3/8 bolts use a lock washer for pressure plate to clutch plate to flywheel ? The tech manual makes no refer. Found it in the parts manual, but it shows with or with out. Help. Thanks J.
Posts: 1,294 |
Never did a 34, but every clutch I worked on used lock washers.
The 1934 and 1937 pressure plates are the same and do use lock washers.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
Like Chevy1937 all the clutches I have done have had spring washers but not tab washers though if you were over cautious tab washers could be used. Tony
Posts: 109 |
Thanks Jean and Tony. I just put the clutch assy together. Your help was app. J.
Posts: 109 |
I missed chevy1937, thank you. J.
