#40382 04/11/06 08:01 PM
Chevgene, The number stamped in my block behind the distributor F517B Does that tell whether the engine has hydraulic or solid lifters? Thanks...Richard
Wilwood Engineering1955-1957
#40383 04/11/06 10:03 PM
If its a 1958 engine -
F made in Flint
517-on May 17th
B-235 Power Glide car
It would have had hyd. lifters when it left the factory.To install solids the cam would have to have been changed later.
#40384 04/12/06 10:41 AM
Ok Chevgene, thanks, It's firing now so I'm in the ballpark.
