Posts: 21 |
I broke a hood spring last week. Anybody got advice on finding a "new" pair? Any hints on replacing them? Looks easy, but I bet it's not.
Local rod shop says they can get me some chromed or stainless springs. That would look strange on my old beater.
Jon Morgan, SC, USA '58 Del Ray 2 dr, post, seamist ("Green 41" in grease pencil writing still on firewall), 99,500miles, 235 6cyl, 3speed column shift, no power nuthin'. No seatbelts, no oil filter.
Posts: 30,700 Likes: 141
Posts: 30,700 Likes: 141 |
New hood springs are available from Classic Chevy International-1-800-456-1957 or classicchevy.com...To install bend spring to one side ,insert flat washer (large) between coils,bend opposite direction-repeat-repeat-----until spring is extended long enough to install.When installed remove washers--no special dangerous tools required.
Posts: 279 |
You may also find the hood springs at www.58chevy.com The springs are not an exact duplicate of the original. I believe the originals had 16 coils - the new may be 14 coils. I find that if your assistant holds the hood up beyond its normal travel, the new spring should "snap" right into place.
Oliver J. Giorgi Technical Advisor 1958 Passenger Car
Posts: 21 |
Interesting trick with the washers! I could apply that elsewhere as well. Thanks y'all.
1 members (swedechev),
78
guests, and
15
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
