Posts: 1,869 |
The other day I tried a section of road that had just been repaved. I was blistering along at 55 when the amp gauge centered itself. I thought that that fancy diode cutout had just done its job. After a while it started to show a discharge. I remembered the last time I had charging issues the resistor on the switch had burned out. It was that again. Any ideas?
Posts: 29,848 |
Posts: 1,869 |
It was right at the top if I remember well.
Posts: 29,848 |
Posts: 1,869 |
I'll check that again. Is it possible that third brush has moved?
Posts: 29,848 |
Posts: 1,869 |
Towards the block is down right?
Posts: 29,848 |
Posts: 1,869 |
I think I've got it. This is at fast idle with the choke on.
Posts: 29,848 |
Driving down the road at 55, the max. output should be about 10 amps. So, what did you do to correct the issue.....re-adjust the third brush?
Posts: 1,869 |
Posts: 29,848 |
Posts: 1,869 |
It is and it was. I guess I hadn't set it low enough the last time.
Posts: 1,869 |
Found out today that this episode had boiled the battery, or perhaps it had been boiling for a while. Anyhow with a new battery, charging at 10 amps I should make it through the summer OK.
Posts: 29,848 |
0 members (),
74
guests, and
8
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
