If the master cylinder is new ignore this:
There are two holes in the bottom of the master cylinder resoroi. Both must be open for it to operate properly. Use a needle and plyers to open the tiny one. Then a suitble device to make sure the bigger one is open as well.
The two holes may be the culprit but should not be if the MC is new.
Good luck,
Charlie
BTW: Adkist tje brale linings to where the lock in place and you can't turn them with your hands. Then back off the adjusting wheel 5 increments or until you can just turn it (the wheel). When driven around the block a couple of times it (internal brake mechanism) will free up and adjust itself to the drum.
To tighten the shoes to the drum: Facing forward the rear adjuster should be turned clockwise to tighten. Facing reward the forward advuster wheel clockwise also. (I'm going by memory here so if I've got this advise on the adjusters wrong someone please correct me. Thanks)
BTW: I believe you will find that the left front is farthest from the MC. In other words following the length of the lines coming off the MC.
